Pioneer IP-Bus Pin hack info
Чип тунинг, Standalone и piggyback електроники.
Ценко изложбения
Регистриран на: 26.11.2003
Местоположение: Регистриран на: 26 Ное 2003 | Мнения: 1117
Кара: дългия да си плати входа !!!
Мнение от rtzankov » 22 Ное 2009, 23:08
Тия сайтове имат навика да изчезва, копирам инфото за по сигурно ;)
Pioneer IP-BUS Hack
This is a virtually free and easy "hack" that requires minimal soldering, and no soldering to the actual pins.
Pioneer has used the proprietary IP-BUS (P-BUS) interface for around 15 years now. This cheap/free alternative to Pioneer's RB10 or RB20 aux-in adapters will allow you to play audio from an mp3 player (iPod, etc.), a laptop, carPC, portable cassette or CD player, or any other device that has an audio out or headphone jack. If you already have a CD changer that is connected to your headunit via IP-BUS, you can still use this hack. Simply splice into the cable, determine which wires go to pins 7, 9, 10, and 11, and splice into them to add the new audio-in plugs of your choice. In this example, I use female RCA jacks from a cable that came with a VCR or stereo once upon a time. Alternatively, you can use a 1/8" (3.5mm) mini stereo connector, if you plan to use only with devices that have a 1/8" audio jack, or get an RCA-to-3.5mm mini jack adapter from RadioShack or other electronics store.
I used these wires and connectors that attatch power and reset switches and LEDs to almost all motherboards. They are perfectly spaced to fit over the pins of the IP-Bus socket. You should be able to get these from a local computer build/repair shop. I'm sure they will have some laying around that you can have, probably for free. All you really need is (1) 3-4 wire connector and (1) 1-2 wire connector.
Using this pin-out schematic, locate your pins.
It's easy to move the wires around if you need to fill empty slots in the connectors. Use a very small screwdriver, pin, or similar to gently lift the little tab that holds the connector in place and slide the wire out. Some of the tabs break easily, and you'll need to have them in their original position to hold the wires in when you reinsert them, so be careful.
Assuming you already have your female RCAs, you may want to connect and solder them before you reinsert the wire clips into the plastic connectors, especially if you plan on using heat-shrink sleeves. Make sure you wire the +/- wires correctly. On an RCA, the center is + and the outer collar is -Ground, red is usually the right channel, and white the left channel. On a 1/8" (3.5mm) jack, the tip is +L, the ring (closest to the tip) is +R, and the sleeve is -Ground. These are the usual/traditional configurations.
Now, you can put the 3-4 wire connector onto the 9-10-11 pins. It is a snug fit. And push the 1-2 wire connector onto the 7 pin. If you have a 2 wire connector, the empty slot can be pushed onto the 3 or 4 pin. I found the 3 pin to be a snugger fit. Now you can band the connectors together with a zip-tie.
Now enjoy your virtually free DIY IP-Bus adapter!
In order to listen to external devices attached to this connector, you must first enable the "AUX" option on the headunit. Consult the manual for your unit for details (Pioneer online manuals). On my headunit, I have to turn the unit off, press and hold the function (F) button for 3 seconds, use the up or down arrows to navigate to the AUX on/off option, select "ON", then turn the unit on again. Then when I press Source on the headunit, AUX will be one of the options.
This is a cleaner, more OEM-style adapter setup, made by heatshrinking 3 4-pin connectors together.
Note that one of the unused pin holes is drilled out to accommodate the metal pin in the center of the IP-BUS socket.
Another possible solution is to remove the wires from the connectors, push them onto the proper pins, and then fill the empty space between the pins in the socket with somthing like hot glue, silicone sealant, Plastisol (the stuff that you can dip tool handles in that forms a thick, rubbery coating), Windo-weld, or something similar that is liquid enough to get down between the pins, but will harden to a firm, rubbery consistency.
This will act like a plug similar to the OEM adapter. If you decide to do this, be advised that there are 3 holes in the socket that will need to be covered by little strips of paper, plastic, tape, etc. before filling up the socket. You might also want to prep the pins and surfaces with a light oil, to keep the filler of your choice from sticking to everything, and permanently sealing up your socket. This could also be done over the plastic connectors and zip-tie for extra stability and a better fit.
R.I.P Landikar
нафтения
Регистриран на: 4.03.2009
Кара: го на спомени
Re: Pioneer IP-Bus Pin hack info
Мнение от Zagy » 23 Ное 2009, 23:54
Тия изводи за чинчове за усилвател ли са?
Ценко изложбения
Мнение от rtzankov » 24 Ное 2009, 10:21
Zagy написа:Тия изводи за чинчове за усилвател ли са?
Не, това е вход "AUX" на пайнерите :)
R.I.P Landikar
Регистриран на: 26.06.2006
Местоположение: Мон
Кара: e60ka
Мнение от krasi_bmw » 09 Яну 2011, 0:16
:yes: става супер
Регистриран на: 23.09.2007
Местоположение: отпред, вляво
Кара: тийнейджърка с M42B18 под полата...
Мечтае да кара: Е92 М3
Детайли за колата: Montrealblau Metallic E36 Coupe СА6577КС
Мнение от roshav » 07 Юни 2011, 0:01
Колеги, а въпроса с USB --> IP BUS как стои за самоделка ?? Че ново, ор'гЕнално струва много пари... :mhihi:
Колата трябва да е немска,
Жената - блондинка,
Ракията - силна, а виното - червено.
Телефонът може и да е Nokia...
Регистриран на: 3.08.2004
Мнение от Bass_Man » 07 Юни 2011, 0:43
Не стои трябва специален чип и софтуер .
Мнение от roshav » 08 Юни 2011, 23:36
:OT: Мамицата им пайнерска... в България излъчват "Пайнерки" боклук-клипове 1080p по тяхната си телевизия за без пари, но не може да си вземеш кабелче с преходник за скъпия плеър, защото стеува много пари и не се внася от никой ... :lol: :lol: :lol:
Но все пак да не изкривяваме темата - пайнера си е пайнер, въпреки ей тези му недостатъци. Аз от 3 години съм с premier deh-p780mp и не ми се сменя с каквото и да било друго :D
Жената - блондинка,
Регистриран на: 29.12.2005
Кара: М4
Мнение от DanielzZz » 08 Юни 2011, 23:43
Аз какво да кажа,като така и не намерих някой да ми настрои импринта на алпайна...
Сега стои под леглото :mhihi:
Мнение от roshav » 10 Юни 2011, 0:59
DanielzZz написа:Аз какво да кажа,като така и не намерих някой да ми настрои импринта на алпайна...
:OT: :OT: :OT:
Колега, тъй като в България ( нашата мила и родна ! ) сме позволили на глупаците, собственици на Техномаркети, -полиси и тем подобни, да владеят пазара за електроника, сме длъжни да се съобразяваме с комерсиално (или поне това, което е такова според тях, Alpine явно не влиза в тази зона), за да можем да получаваме "адекватно" обслужване за продуктите, които сме закупили за много пари :cry:
Съчувствам ти, защото съм го изживявал стотици пъти - да поискаш да си платиш да ти свърши някой "разбирач" работа и да не може, защото "не става !!!"... Българинът просто, в масовия случай, не знае как да ти вземе парите (освен с кражба - там сме №1). Съвет - не се отказвай със CD-то под леглото, в един момент ще изкочи някъде, някой гаражен жичкаджия, който ще ти го направи за никакви пари, защото МОЖЕ и ИСКА :!: :!: :yes: :yes:
Последна промяна roshav на 13 Юни 2011, 0:07, променена общо 1 път
Жената - блондинка,
Мнение от Bass_Man » 11 Юни 2011, 16:12
Купуваш си ето това : http://www.amazon.com/KTX-100EQ-Alpine- ... B000XPM3P2
и си го настройваш сам . Не виждам къде е драмата ?
Според мен проблема е в купувачите , а не в продавачите . Просто трябва да се прави разлика между търговец и човек , който предлага услуга . А в БГ хората искат през търговеца и неговата цена да получат услуга . Еми няма как да стане .
Кара: М4
Мнение от DanielzZz » 15 Юни 2011, 14:11
Драмата е,че не ми се дават 200 долара само за 1 настройка.Ако някой разполагаше с такова,с удоволствие щях да му дам 50лв за да ми импринтне колата.
Иначе от плеъра не съм се отказал,той си свири добре и без да е импринтнат,просто продадох колата и сега чакам да го забода на някоя друга каляска. :mhihi:
Мнение от roshav » 16 Юни 2011, 1:03
Брат, не съм сигурен, че е невъзможно да се направи и за по-малко пари... въпрос на проучване е КЪДЕ... :yes:
Жената - блондинка,
Назад към Електроника
