Има ли духове или аз се побърквам ?
- Feanor
- Регистриран на: 18.01.2007
- Кара: E39 535i '01
- Мечтае да кара: Mки, Ферарита и други глупости :)
Re: Има ли духове или аз се побърквам ?
DanielzZz написа:Някъде бях прочел,че ниските честоти(инфразвук) също събуждат такъв страх в човека.
Tочно така, тук например. Един интересен цитат от там:
Research by Vic Tandy, a lecturer at Coventry University, suggested that an infrasonic signal of 19 Hz might be responsible for some ghost sightings. Tandy was working late one night alone in a supposedly haunted laboratory at Warwick, when he felt very anxious and could detect a grey blob out of the corner of his eye. When Tandy turned to face the grey blob, there was nothing.
The following day, Tandy was working on his fencing foil, with the handle held in a vise. Although there was nothing touching it, the blade started to vibrate wildly. Further investigation led Tandy to discover that the extractor fan in the lab was emitting a frequency of 18.98 Hz, very close to the resonant frequency of the eye given as 18 Hz by NASA. This was why Tandy had seen a ghostly figure—it was an optical illusion caused by his eyeballs resonating. The room was exactly half a wavelength in length, and the desk was in the centre, thus causing a standing wave which caused the vibration of the foil.
Ето как и свръхестественото имало естествено обяснение, стига да подходиш към него научно и без суеверия.
"Nothing gives one person so much advantage over another as to remain always cool and unruffled under all circumstances"
- DanielzZz
- Регистриран на: 29.12.2005
- Кара: М4
Съгласен съм с теб,но само наполовина.Наистина в повечето случай е чиста илюзия,породена от инфразвук,умора на очите и т.н.,но не изключвам възможността да съществуват такива явления.
- Feanor
Аз също не изключвам напълно такава възможност, защото далеч не знаем всичко за света около нас. Обаче подлагам на съмнение всяко такова твърдение, просто защото доказателства няма.
Feanor, търсиш под вола теле.
- Feanor
Защото...?
- ///peter
- Регистриран на: 24.11.2006
- Кара: Жи55АЕМЖИ
- Мечтае да кара: 911 turbo
HX52 Holset
MS 1 Extra - ECU
Inovate wide band
Feanor написа:Защото...?
Защото цитираното от теб достоверно изследване е много частен случай.
- Feanor
То че е частен случай - частен случай е. Но е доказано обяснение - тоест в този частен случай не само, че волът се е оказал крава, а сме намерили и теле отдолу. Предвид, че е всички доказани обяснения са все в тоя дух, не виждам причина да не търсим подобни обяснения и на останалите случаи. Не че непременно обясненията ще са точно такива, но е нелоша евристика.
- ///peter
- Кара: Жи55АЕМЖИ
HX52 Holset
MS 1 Extra - ECU
Inovate wide band
Feanor написа:То че е частен случай - частен случай е. Но е доказано обяснение - тоест в този частен случай не само, че волът се е оказал крава, а сме намерили и теле отдолу. Предвид, че е всички доказани обяснения са все в тоя дух, не виждам причина да не търсим подобни обяснения и на останалите случаи. Не че непременно обясненията ще са точно такива, но е нелоша евристика.
Вероятно от висотата на своето незнание, ми се струва смешно да се търси като причина за среща с духове наличие на 18 херцови излъчватели на аудио вълни, в подходяща 8 метрова стая
- Feanor
По-малко смешно ти се струва да търсиш проявления на непознати нематериални сили, които никой не е срещал и регистрирал? И които не се вписват в никой от текущите модели за вселената? Аз по-скоро бих търсил източници на подходящи вълни... най-определено...
- ///peter
- Кара: Жи55АЕМЖИ
HX52 Holset
MS 1 Extra - ECU
Inovate wide band
Feanor написа:По-малко смешно ти се струва да търсиш проявления на непознати нематериални сили, които никой не е срещал и регистрирал? И които не се вписват в никой от текущите модели за вселената? Аз по-скоро бих търсил източници на подходящи вълни... най-определено...
Защо така категорично отричаш неща които не познаваш? До скоро и за неутрино се казваше от научни светила като теб, че е невъзможно да има, но...
А ако трябва да бъдем честни, това е и проблема на днешната наука, прекалено ограничена е от към фантазия и за това боксуваме здраво във всички направления.
Но ще ми бъде интересно да прочета все пак твой научен труд? Демонстрираш много знания, вероятно си физик?
- Larbi
- Регистриран на: 28.10.2009
- Кара: каквото има
- Мечтае да кара: FERRARI 458 Italia
ОФ Топик за който се извинявам предварително:
Ееееее Феанор , Петер ! Стегнете се малко защото изобщо не ми е приятно да спорите тука така при положение, че сте супер единни по темата за конспирациите и извънземните
- Feanor
///peter написа:Защо така категорично отричаш неща които не познаваш? До скоро и за неутрино се казваше от научни светила като теб, че е невъзможно да има, но...
По същата причина, поради която не вярвам, че всеки неопределен обект в небето е посетител от Андромеда - "exceptional claims require exceptional proof". А твърдението без никакво съмнение е необичайно - не виждаш духове всеки ден, нали? И тук, също както и с извънземните, не изключвам напълно възможността за нещо адски странно и напълно непознато. Просто си искам proof-a.
///peter написа:Демонстрираш много знания, вероятно си физик?
Физиката ми е слабост, но не съм я учил конкретно нея - само колкото е необходимо покрай електротехниката и електрониката.
- ///peter
- Кара: Жи55АЕМЖИ
HX52 Holset
MS 1 Extra - ECU
Inovate wide band
larbi написа:ОФ Топик за който се извинявам предварително:
Нормално, конспирациите имат страшни измислици, които дори и аз се размазвам като ги чета
П.С. рептил съм
Feanor написа:///peter написа:Защо така категорично отричаш неща които не познаваш? До скоро и за неутрино се казваше от научни светила като теб, че е невъзможно да има, но...
Давай го на БГ, такива щатски сложни изречения много ме напрегат.
Проблема, както говорихме е от там, че модерната наука е лишена от авантюризъм и за 60 години, такъв голям период от време почти нищо ново не е открито.
Ще ти цитирам само времето, като изключително измислена история на която се базират много открития и физични закони. Но поради факта, че физиците на които се опитваш да подражаваш, казват "така е" и никой не си прави труда да прави проучвания на тази тема.
- Сондьора
- Регистриран на: 21.10.2007
- Кара: E36 M52b20 Touring
А и физиците са нищо повече от наблюдатели служещи си с математика .
И Feanor, дано знае що нема нобелова награда за математика
- Larbi
- Кара: каквото има
///peter написа:larbi написа:ОФ Топик за който се извинявам предварително:
Нормално, конспирациите имат страшни измислици, които дори и аз се размазвам като ги чета![]()
П.С. рептил съм![]()
Напротив! И тук и там има някакви неща които вероятно никога няма да бъдат написани в учебниците не по физика ами по нищо
П.С. Обикновен АНУНАКИ съм! Обикновен обикновен, колко да съм обикновен АНУНАКИ просто сина на Краля
