В Япония ги смачка - 9 по Рихтер, 10м Цунами...
- Totogada
- Регистриран на: 13.02.2006
- Местоположение: Сливен
- Кара: ше E36 320 Coupe
Re: В Япония ги смачка - 9 по Рихтер, 10м Цунами...
Снимките са покъртителни
Горките японци.
Горките японци.
R.I.P. Champion 1968 – 2007 Colin McRae
- steeN
- Регистриран на: 7.04.2004
- Местоположение: CA
- Кара: конете да бягат
не са били графит пръчките... ядрото е направено от графитни тухли, в които се слага урана и в тях се спускат пръчките, които са казах от какво
- The only easy day was yesterday.
- Сондьора
- Регистриран на: 21.10.2007
- Кара: E36 M52b20 Touring
With no more coolant, the fuel heated up and became molten. Standing graphite rods in the reactor ignited into a very hot graphite fire that began spewing bits of the radioactive fuel into the open air.
Незнам кво е било...
- steeN
In order to create additional power, it was necessary to raise some of the boron control rods. By safety specification, it was mandatory that a minimum of 28 of the 210 rods be maintained at all times in the core. At the moment of decision, that is all there were in the core. When the reactor exploded, there were only 18 left.
With the extraction of the rods, the power levels rose to about 200 megawatts before it leveled out due to the poisoning in the reactor. It was still 600 less than the minimum operational reactor reserve. The engineers were scrambling to maintain proper levels on the water circulation, the steam pressure and the power levels. At this point, 2 minutes from the explosion, they still could have stopped it. All it would have taken was for them to carefully power down the reactor.
... не знам това е странно щото на снимката това не е "rod". а и не мисля, че графита има такива свойства, като бора.
- spacepl
- Регистриран на: 29.03.2007
- Местоположение: Pleven
- Кара: E60 530D F07 530D
http://www.world-nuclear-news.org/rss.aspx
14 Март 2011 г., 22:27:33 | Jeremy Gordon
BREAKING NEWS Serious damage to the reactor core of Fukushima Daiichi 2 seems likely after coolant was apparently lost for a period. Seawater is again being injected, but coolant level is unknown.
Лоша работа
Лоша работа
Последна промяна spacepl на 15 Мар 2011, 0:41, променена общо 1 път
- Mollov
- Мародератор
- Регистриран на: 28.07.2006
- Кара: some d20s
Пичове, стига спорили за глупости...
- ditko1
- Регистриран на: 24.10.2006
- Кара: Bmw x5 4.4
- Мечтае да кара: Муха
Обаче може и да има нещо общо със луната дето ще е най-близо от 19г насам. Все пак си има някаква гравитация, може малко да му е трябвало за да се случат нещата, може и да няма общо.
- vicho
- Регистриран на: 3.09.2003
- Кара: M340i
- Мечтае да кара: Калибра
ditko1 написа:Обаче може и да има нещо общо със луната дето ще е най-близо от 19г насам. Все пак си има някаква гравитация, може малко да му е трябвало за да се случат нещата, може и да няма общо.
повече вярвам на това, че гравитацията на луната е причина за катаклизъма, отколкото както пише колежката, че Майката Природа "стои" зад всичко
всъщност Луната има доста голямо значение за живота на Земята и не е само един огромен камък, който обикаля около нашата мила планета
Попаднах на една мнооого интересна статия, на който мy е интересно: http://www.capital.bg/politika_i_ikonomika/sviat/2011/03/14/1059248_molia_bez_panika/
Имало е и нова експлозия. Персоналът е евакyиран, само 50 човека са останали.
Последна промяна krystal на 15 Мар 2011, 4:23, променена общо 1 път
vicho написа:всъщност Луната има доста голямо значение за живота на Земята и не е само един огромен камък, който обикаля около нашата мила планета
и аз мисля така, нали точно луната влияе на приливите и отливите, следователно оказва влияните върху гравитацията, може да бъркам..
I am beton!
Вчера ме изпревари една седмица е23 и само като му видях намръщената физиономия в огледалото и послушно се дръпнах вдясно да му направя място да минеА то едно такова лъскаво четкано, лелеййй Акула!
- exvitermini
- Регистриран на: 4.12.2005
- Местоположение: Михайловград
- Кара: '96 Е34 tds touring Individual
- Мечтае да кара: E34 M5 Touring
фастъка написа:vicho написа:всъщност Луната има доста голямо значение за живота на Земята и не е само един огромен камък, който обикаля около нашата мила планета
http://www.vbox7.com/play:2c58e922 Тайните на Луната част 1 и 2
http://www.vbox7.com/play:79fb5ce3
- Alpina_fanatic
- Регистриран на: 23.12.2010
Япония е съобщила на Международната агенция за атомна енергия (МААЕ), че хранилище за отработено гориво се е запалило в реактор, пострадал от земетресението и радиоактивни частици са попаднали "директно" в атмосферата.
поне си признават, а не като чернобил и в стокхолм се чудат кой ял яйца и пръднал
не съм черноглед, ама има доста голям риск чернобил да се повтори и вече
всичко квот искаше да удължава живота на разни реактори и да строят нови аец-ве се дърпат
не съм гриийпийс фреак, ама отдавна трябваше всички да се насочат към еко енергия и да заебат чистия и "евтин ток",
а япония с тва разположение, можеше да си прави целия ток от приливите и отливите
само да спомена, че нашият аец е доста сходен с чернобил, а той по рожба е направен зле,
само дето името Козлудуй е по-подходящо за аварията унищожила европа
Последна промяна acer на 15 Мар 2011, 13:29, променена общо 4 пъти
- Mollov
- Мародератор
- Кара: some d20s
Alpina_fanatic написа:Япония е съобщила на Международната агенция за атомна енергия (МААЕ), че хранилище за отработено гориво се е запалило в реактор, пострадал от земетресението и радиоактивни частици са попаднали "директно" в атмосферата.
Към момента обаче всички тия радиоактивни частици са "заминали" над океана и няма директна опасност...
- Alpina_fanatic
Mollov написа:Alpina_fanatic написа:Япония е съобщила на Международната агенция за атомна енергия (МААЕ), че хранилище за отработено гориво се е запалило в реактор, пострадал от земетресението и радиоактивни частици са попаднали "директно" в атмосферата.
В префектура Сайтама, която е част от т.нар. Голямо Токио, обаче нивото на радиация е 40 пъти над нормата, съобщиха от токийското кметство. В префектура Канагава, на югозапад от Токио, равнището на радиацията се е увеличило между 6 и 9 пъти в сравнение с нормалното. Повишена радиация е била измерена и в префектура Тотиги.Икономедия
