При вкл. подгряване на задно стъкло - смущение на радиото.
12 мнения
Колеги, кажете къде да търся хлабавата връзка, моля?
Re: При вкл. подгряване на задно стъкло - смущение на радиото.
не знам до каква степен е смущението при теб, но в друга тема колеги казаха, че е нормално да има известно смущение
ето ти още нещо за четене
© написа:това може би е интересно
Poor Radio ReceptionWhat year is your car?
If you are pre-2002 (ish) with diversity FM receiver you will have an FM amplifier with two antenna cables. The smaller antenna cable carries DC to turn on the rear FM amplifer. It also selects the optimum diversity antenna by use of three carrier tones from the headunit.
This FM amplifier is no good for aftermarket head units and you need to swap it with a later FM amplifier that only has one FM cable. The diversity selection is all integrated into the later model FM amplifier. They come in at about £20 on eBay.
Next you need to turn on the new amplifier by injecting 12V up the antenna connector. You can't just connect 12V to the coaxial cable centre core, since it mucks up the 75Ohms controlled impedance and connects your sensitive FM receiver to your noisy car wiring. Not good.
You need to search "amplified adapter" with either "DIN", "ISO" or "FAKRA" depending on what connectors you want for your year of car. This device is large because it has a tuned circuit to inject 12V onto the coax without affecting the 75Ohms impedance, filtering out noise from the vehicle and protecting the FM receiver in the Dynavin from the 12V (make sure you get the adapter the right way round!)
This thread on e46 fanatics shows how to do the swap of the FM amp (you will need a ratchet spanner to get at one of the screws). Page 4 has a post on the 12V FM adapter.
от тук http://bbs.dynavin.com/viewthread.php?t ... a=page%3D1
и всъщност истинската тема http://forum.e46fanatics.com/showthread.php?t=396343
- DiMIcha84
- Регистриран на: 30.07.2009
- Кара: Е39 525д 2001
- Мечтае да кара: F13 с М буквичка.
То и при мен се смущава и си мисля, че е нормално колега.
- Dimitroff
- Фен на тройките
- Регистриран на: 21.02.2007
- Местоположение: СА,Х
- Мечтае да кара: ;)
За Е46 преди фейса ли става дума, колега?
- ceno83
- Регистриран на: 5.06.2007
- Кара: БМВ 320D 2001
- Мечтае да кара: M Power
При мен има смущения като пусна фаровете
,,Болката от сполетялото ни нещастие се дължи не на самото събитие,а на нашата оценка за него.А тъкмо нея ние можем да променим във всеки един момент."
- pazokolarov
- Регистриран на: 26.01.2007
- Кара: 320dA 525xd
Колега, ето ти още една такава тема, но за комби
viewtopic.php?f=34&t=177333
При мен проблема вероятно е от антенния усилвател, зашото сложих стария, който беше на моето стъкло, а вероятно трябваше да сложа този от новото стъкло.
При теб схемата е по-елементарна и имаш само един антенен усилвател.
А за всички, останали с впечатлението, че при вкл. на някакъв консуматор е нормално редоиприемането да се влоши - НЕ Е НОРМАЛНО.
Описъл съм проблема подробно в моята тема и той се появи след смяната на стъклото. Сега по магистрала Хемус след 10-15-ия км започва да ми се губи сигнала, а преди сигнала изчезваше, и то не непълно, чак по средата на планината.
Сега чакам затоплянето за да предприема мерки ...
- Toni 74
- Регистриран на: 9.08.2006
- Местоположение: VRATSA
[quote="ceno83"]При мен има смущения като пусна нагревателя а навън вали
- Е.Димитров
- Регистриран на: 27.03.2009
- Кара: F
- Мечтае да кара: Самолет
Вижте какво колеги-не е нормално да има смущения ,смущения се получават когато няма добра връзка някъде ,самото "бъздене" при не-добра връзка излъчва електромагнитни вълни и от там смущението,проверете си връзките там където слизат в реотана на стъклото,дефакто този реотан е голям консуматор и съпротивлението е голямо,някъде "изкри" връзката...
в интерес на истината и аз нямам смущения от нагревателя
Преди фейса е колата. Значи се намира на лявата задна колона, нали не бъркам?!
- dobroslav85
- Регистриран на: 4.04.2016
Колеги някои може ли да помофне като включа подгрева на задното стъкло светва лампата за динамото
12 мнения
