X6 M 0-60mph 4.3s + Х5 М
Регистриран на: 5.04.2005
Мнение от MaXimal » 07 Окт 2009, 23:16
Specifications:
Drive Type: All-wheel drive
Transmission Type: Six-speed manual
Engine Type: Twin-turbo V8
Displacement (cc/cu-in): 4,395cc (268cu-in)
Redline (rpm): 7,000
Horsepower (hp @ rpm): 555 @ 6,000
Torque (lb-ft @ rpm): 501 @ 1,500
Brake Type (front): 15.6-inch ventilated cast-iron disc with two-piece rotors and 4-piston fixed calipers
Brake Type (rear): 15.2-inch ventilated cast-iron disc with two-piece rotors, and 2-piston sliding calipers
Steering System: Speed-proportional, driver-selectable hydraulic-assist rack-and-pinion power steering
Suspension Type (front): Independent, double wishbone, coil spring, driver-adjustable variable dampers, self-adjusting active antiroll bar
Suspension Type (rear): Independent, multilink, self-leveling air springs, driver-adjustable variable dampers, self-adjusting active antiroll bar
Tire Size (front): 275/40R20 106W
Tire Size (rear): 315/35R20 110W
Tire Brand: Bridgestone
Tire Model: Dueller H/P Sport
Tire Type: Summer Performance
Wheel Size: 20-by-10 inches front -- 20-by-11 inches rear
Wheel Material (front/rear): Aluminum
As tested Curb Weight (lb): 5,256
Test Results:
0 - 30 (sec): 1.7
0 - 45 (sec): 2.9
0 - 60 (sec): 4.3
0 - 75 (sec): 6.4
1/4 Mile (sec @ mph): 12.6
0-60 with 1 foot of rollout (sec): 4.1
30 - 0 (ft): 28
60 - 0 (ft): 107
Braking Rating: Excellent
Slalom (mph): 68.6
Skid Pad Lateral acceleration (g): 0.91
Handling Rating: Very Good
Db @ Idle: 43.3
Db @ Full Throttle: 70.4
Db @ 70 mph Cruise: 66.0
Добри характеристики :D
За по-любознателните -> http://www.xbimmers.com/forums/showthread.php?t=309098
Дойде времето и на Х5 М
"Stats...
0-60: 4.5s
0-60 w/ rollout: 4.2s
1/4 mile: 12.8s @ 108.5mph
60-0: 116ft
Slalom: 63.5mph
Skidpad: 0.91g"
Последна промяна MaXimal на 09 Окт 2009, 8:06, променена общо 1 път
Регистриран на: 29.06.2009
Кара: 320i E46,Е30+М50b25(stroke)
Мечтае да кара: M3 Е92 DCT,М5 2011 F10
Детайли за колата: Спортно окачване FK High Sport M3(Coilover-реголируемо),спортна генерация на 63мм+спортни резонатори,плетен спортен колектор,иридиеви свещи Denso Iridium IK20,шорт шифтър на ACT,сменен дросел,cold air intake-K&N,олекотени жданти R15(магнезиеви)BMW/4.5кг(с гума 12.2кг).Горивен регулатор JDM(SARD).Горивна мопма от Ауди(7.0bar.)с армирани горивни маркучи.Частично олекотяване,Recaro 9.8кг(състезателна седалка),крайно тегло с 15л бензин(1288кг),разпънки(реголируеми-HKS),полу-сликове ADVAN A032R
Re: X6 M 0-60mph 4.3s
Мнение от Бимбо » 07 Окт 2009, 23:21
Да на болид, не на джип :D :lol: :lol: :shock:
devildriver
Регистриран на: 21.04.2002
Кара: E30
Мечтае да кара: McLaren F1
Мнение от SlipKnoT » 07 Окт 2009, 23:39
от 60мили до 0 за 32.61метра... зло! :shock:
Старши Алкохолик
Регистриран на: 13.03.2006
Кара: E60 LCI 535d
Мечтае да кара: E24 635CSi
Мнение от zAcK » 08 Окт 2009, 0:35
:shock: :shock: :shock:
Сега пак ще се появи някой и ще каже, че Е30 е по-добрия автомобил, че и по-красивия :banghead:
Гаранция. Иначе това е станало бая чудовище :mrgreen:
2384 килограма :roll:
Любимец на Кралицата
Регистриран на: 6.04.2008
Мечтае да кара: M3 CSL
Мнение от ///M_Martin » 08 Окт 2009, 0:43
zAcK написа::shock: :shock: :shock:
:mhihi: :mhihi: :mhihi: :yes:
Регистриран на: 19.09.2008
Местоположение: Burgas
Кара: **** ми янко
Мечтае да кара: CL65 AMG
Мнение от LizarD » 08 Окт 2009, 1:30
Расов звер :mhihi: Тая кола е чист секс
Регистриран на: 7.04.2004
Местоположение: CA
Мнение от steeN » 08 Окт 2009, 4:10
аз искам да знам тия числа какви са при x5m...
Slalom (mph): 68.6
Мнение от MaXimal » 08 Окт 2009, 7:58
Представяте ли си го този двигател в нещо по-лекичко... М5 например ;)
Старши Алкохолик
Кара: E60 LCI 535d
Мнение от zAcK » 08 Окт 2009, 8:51
:twisted: Е то на М5 двигателя няма да е по-лош :driving: :ok:
Старши Алкохолик
Кара: E60 LCI 535d
Мнение от zAcK » 08 Окт 2009, 8:57
:shock: :shock: Тия вече ги поръчват, мамка му. Как им завиждам и на възможностите и на всичко :bowdown:
Старши Алкохолик
Кара: E60 LCI 535d
Мнение от zAcK » 08 Окт 2009, 8:59
Е ето какво казват хората по повод на хейтърите, които не спряха да мрънкат, че Х6М било безсмислено:
It's a triumph of engineering over design and marketing.
Мнение от MaXimal » 08 Окт 2009, 9:18
[quote="zAcK"]:shock: :shock: Тия вече ги поръчват, мамка му. Как им завиждам и на възможностите и на всичко :bowdown:[quote]
http://suchen.mobile.de/fahrzeuge/showD ... eNumber=28
А БМВ са си го нарекли "Uncompromisingly different."
Регистриран на: 12.11.2006
Кара: ги да пият мента
Мечтае да кара: за 6лв/100км
Мнение от павката » 08 Окт 2009, 17:13
500-ин нютона при 1500об,браво
ама при тия 2 виялки,ще има още резерв май :roll:
Регистриран на: 24.07.2002
Мнение от Mini » 09 Окт 2009, 4:24
павката написа:500-ин нютона при 1500об,браво
Колега, 501 lb-ft се равняват на 679 Nm !!!
Re: X6 M 0-60mph 4.3s + Х5 М
Мнение от MaXimal » 09 Окт 2009, 8:07
Х5 М
Stats...
0-60: 4.5s
60-0: 116ft
Slalom: 63.5mph
Skidpad: 0.91g
http://www.xbimmers.com/forums/showthread.php?t=309478
Назад към Основен Форум
