бушони
3 мнения
- bumer(e34)
- Регистриран на: 25.02.2009
бушони
някои ше ми каже ли на кои номер бошон какво отговаря липсват ми бушони и незнам за какво липсват
- Простак
- Старши Алкохолик
- Регистриран на: 31.10.2007
- Кара: колата да харчи
!!Asen_X написа:Има такива теми ей ... ползвай търсачката![]()
Ето ти за троен стоп:
Fuses Fuse # Rating
1 7.5 A Left high beam
2 7.5 A Right high beam
3 15 A Aux. cooling fan, low speed
4 15 A Indicators/emergency hazards lights; Active Check control; digital Clock
5 30 A Wipers and washers
6 7.5 A Stop light; cruise control; Active Check control; ABS; interior lights
7 15 A Horn
8 30 A Rear demister
9 15 A Fuel delivery; Idle speed control
10 7.5 A Seat belt warning system; service interval indicator; tachometer/fuel economy gauge; instrument gauges; brake warning system; back-up lights; OBC; starter; fuel delivery; idle speed control; Active Check control; stop lights and cruise control
11 7.5 A Fuel pump
12 7.5 A Radio; speedometer/instdument indicators; OBC; Multifunction Clock
13 7.5 A Left Low Beam
14 7.5 A Right Low Beam
15 Not Used
16 15 A Heated Seats
17 30 A Sunroof; electric windows
18 30 A Aux. cooling fan, high speed
19 7.5 A Aux. cooling fan; interior lights; electric mirrors
20 30 A Heater/air conditioning; auxiliary radiator cooling fan
21 7.5 A Glovebox light; flashlight socket; ignition key/keat belt warning; Interior Lights; radio memory; boot light; Active Check control; Service Interval indicator; OBC; fuel delivery; tachometer/fuel economy gauge; Clock
22 7.5 A Active Check control; front parking lights; taillights; front side marker lights
23 7.5 A Dashboard lights; front Parking lights; taillights; rear side marker/license plate lights; Active Check control; rear defogger; multi-function clock; OBC
24 15 A Indicators/emergency hazard lights
25 Not Used
26 Not Used
27 30 A Interior lights; central locking; OBC; radio amplifier
28 30 A Lighter; powered aerial
29 7.5 A Left fog light
30 7.5 A Right fog light
Ето мисля че ще ти свърши работа
Другия път пробвай с търсачката
- Стаевски
- Регистриран на: 15.01.2009
- Местоположение: Свищов
- Кара: Е30 318i
- Мечтае да кара: Комби
"айде и на кирилица...
1. - 7,5 А - Дълги светлини, ляв фар
2. - 7,5 А - Дълги светлини, десен фар
3. - 15 А - Допълнителен вентилатор, 91 % С
4. - 15 А - Мигачи
5. - 30 А - Чистачки на стъклата, устройство за измиване на стъклата, у-во за измиване на фаровете, с-ма за интензивно почистване на фаровете
6. - 7,5 А - Стоп светлини (при допълнителни стоп-светлини 15 А) автоматично регулиране на скороста
7. - 15 А - Клаксон
8. - 30 А - Нагревател на задното стъкло
9. - 7,5 А - Електрооборудване на двигателя (при карбуратерен двигател), сигнализиране за включения режим при автоматична скоростна кутия
10. - 15 А - ---------------
11. - 7,5 А - Прибори, бордови компютър, светлини за заден ход
12. - 7,5 А - Радиоприемник, система за чек-контрол и прибори
13. - 7,5 А - Къси светлини, ляв фар
14. - 7,5 А - Къси светлини, десен фар
15. - 7,5 А - Задни фарове против мъгла (реле К4, изключване при включени дълги светлини - реле К9)
16. - 15 А - Нагряване на седалките
17. - 30 А - Люк на покрива, ел. Стъклоповдигачи
18. - 30 А - Допълнителен вентилатор 99 % C
19. - 7,5 А - Електрическо задвижване на външното огледало, нагревател на външното огледало
20. - 30 А - Вентилатор, климатична инсталация
21. - 7,5 А - Осветявани на купето, осветяване на жабката, осветяване на багажния отсек, подвижна лампа, памет на радиоприемника, часовник, бордови компютър
22. - 7,5 А - Десни габаритни светлини, осветяване на регистратиционния номер, осветяване на приборите
23. - 7,5 А - Леви габаритни светлини, осветяване на регистрационния номер, осветяване на приборите
24. - 15 А - Система за аварийна сигнализация
25. - 30 А - ----------------------
26. - 30 А - ----------------------
27. - 30 А - Система за централно заключване на вратите, нагреватели на ключалките, система за аварийна сигнализация, борд компютър, клаксон
28. - 30 А - Запалка, автоматична антена
29. - 7,5 А - Преден фар против мъгла, ляв
30. - 7,5 А - Преден фар против мъгла, десен
К 1 ............ Реле на допълнителния вентилатор, първа степен
К 2 ............ Реле на клаксона
К 3 ............ Реле на дългете светлини
К 4 ............ Реле на късите светлини, задните фарове против мъгла
К 5 ............ Реле на на гревателите на седалките, люка на покрива, ел. Стъклоповдигачи
К 6 ............ Реле на допълнителния вентилатор, втора степен
К 7 ............ Реле на вентилатора на отоплението, ел задвижване на външното огледало
К 8 ............ Реле на фаровете против мъгла
К 9 ............ Реле на задните фарове против мъгла (Франция, Швейцария)
К 10 .......... Реле на блока за управление на интензивното почистване на фаровете
4. - 15 А - Мигачи
7. - 15 А - Клаксон
3 мнения
