ХАК ЗА М3 (ускорен старт)!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Регистриран на: 25.03.2004
Местоположение: София , Люлин
Мнение от bgtroll » 27 Мар 2004, 3:01
Дали действа нямам ама никаква представа... но звучи много добрее...
:roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll:
There's a cheat code in the software running the BMW M3's sequential manual gearbox (SMG). Press the right buttons in the right order and the car will launch you from a stop after revving the engine to 5,000 rpm.
Basically by performing the cheat code listed below it will launch the car from the line at maximum possible acceleration without wheel spin.
But there is a limitation. In Europe doing more than 15 launches using this method voids the car's warranty. Federal laws prohibit this in the USA so BMW has decreased the revs so they are preprogrammed to wind to only 2,500 rpm where as European models can range to 5000 rpm. Therefore this method works much better on European models.
Procedure
Switch off the stability system and select shift program six
Switch the engine to sport mode
With the hand shifter in drive, hold it in the downshift position and press the accelerator pedal. (the engine will rev to the preprogrammed rpm (5000 rpm on the european software, 1800-2500 on the american software )
Release the shifter
The car will launch forward violently and the engine's revs will climb quickly, so be prepared to up shift.
Enjoy!
Notes
This method can possibly cause damage to the transmission and after 15 launches the car's warranty will be void.
SMG was introduced on the E46 shapes, therefore this is the only model of the 3 Series in which this hack will work.
:arrow: http://www.dalartworks.co.uk/bhangra/hack_m3.php
Друга страница, която разглежда по-горното:
http://www.popsci.com/popsci/auto/article/0,12543,358540,00.html
master of the force
Регистриран на: 11.08.2003
Местоположение: planet torque
Мнение от alx » 27 Мар 2004, 4:28
това е стандартната процедура за старт (launch control) на смг 1 и смг 2...
алекс
трабант 601с
разни други возила
IBIZA Killer
Регистриран на: 6.03.2003
Местоположение: North Hollywood
Мнение от bawareca » 27 Мар 2004, 4:35
И не може да правиш повече от 1 старт за 1 час :shock: А па след 10 отиваш при дилъра да ти сменят саединитела :arrow: така е по манюала :cry:
devildriver
Регистриран на: 21.04.2002
Кара: E30
Мечтае да кара: McLaren F1
Мнение от SlipKnoT » 27 Мар 2004, 15:20
Да си карат СМГ'та колкото щат.. аз си искам добрата стара (не чак толкова) 6 "зъбна" лудница :!: :twisted:
Регистриран на: 14.02.2004
Кара: '02 BMW E46 330i
Мнение от ///M3 » 27 Мар 2004, 17:51
SlipKnoT написа:...
:yes: И аз съм на това мнение !
Потребители разглеждащи този форум: TNT
