Питане за дистанционно за печка
5-та серия ('04 - '10)
Регистриран на: 4.06.2007
Кара: E60 530D
Re: Питане за дистанционно за печка
Мнение от lowlevel » 07 Окт 2011, 18:37
Малко търсене в Гугъла връща информация за всички бенефити от печката:
As you are aware, the BMW 5 Series Diesel is fitted with the Webasto Thermo Top C fuel-burning heater as standard, which is used as a supplementary heater. In this application, the Webasto heater only operates when the engine is running and the outside temperature is below 5°C. In conjunction with BMW GB, we have developed a simple upgrade, which includes the addition of a simple electrical interface harness, which will switch the heater on independently.
The parked car heater is started by a remote control device and warms the coolant independently from the vehicle's engine. The vehicle's blower system takes the warm air into the cabin and, at the same time, pre-heats the engine.
Once this upgrade has been installed, it will provide pre-heating for your vehicle prior to commencing your journey.
Some of the benefits associated with such a system are as follows:
· Warmth and comfort of a pre-heated interior - a centrally heated interior.
· Screen defrost and demist - increase safety with a safer clearer vision through the windscreen at the start of your journey.
· Pre-heated engine - no more cold starts/easier starting.
· A pre-warmed engine - a better engine response from cold.
· Reduced engine wear
· Reduced engine emissions - lower emissions from a preheated engine.
· "Just drive off straight away and enjoy your journey."
The standard installation includes full system integration with the parking heater controlled by a Telestart Remote Control. This allows switching on and off of the system by a remote control handset with a range of 600 metres.
Регистриран на: 14.03.2010
Кара: '16 550d
Мнение от Emooo » 07 Окт 2011, 18:55
lowlevel написа:the BMW 5 Series Diesel is fitted with the Webasto Thermo Top C fuel-burning heater as standard
Това означава ли че всички имат печки? И ако да как да ползвам печката ако нямам дистанционно.
Сега намерих в нета от къде си взел този текст. Първо запитването е за е39 и предполагам отговоря е за някоя от страните на север, където е логично да има печка като стандартно обурудване.
Tool - Fear Inoculum
Регистриран на: 27.10.2009
Местоположение: в гащите си
Кара: ги да викат
Мечтае да кара: слон
Мнение от bvv1 » 07 Окт 2011, 20:42
da6ip написа:колеги малко оф-топик, ама наскоро с изненада разбрах че печката на Е60/61 не подргява двигателя, а само салона!
причината била че за двигателя щяла да отива много енергия и да смаже акумулатора, та инженерите решили с печката да се отоплява само салона. за целта се загрява по-малко количество антифриз и той си циркулира само през климатика.
може ли някой да потвърди или отрече това?
Печката затопля двигателя, но чертичките мърдат много малко горе-долу за половин часа работа падат две черти(което е напълно достатъчно за така нареченият топъл старт) и затова може би не ги забелязвате!Освен това зимата печката се включва без да и задавате нищо винаги при първоначалното палене на колата когато е студена за да помогне за по бързото затопляне на купето и това е при всички БМВта с печки!
Преди да полетиш-трябва да се научиш да ходиш!
Регистриран на: 27.08.2010
Кара: на бензин
Мнение от Roman 1 » 07 Окт 2011, 21:58
Emooo написа:lowlevel написа:
Тази извадка ми намирисва на нещо канадско или скандинавско. Само там въпросната печка би могла да бъде част от стандартно оборудване. Иначе не виждам смисъл от нея при Е60, които са за по-топлите страни.
В списъка с оборудването на Е60 за БГ пазара тази опция се води "Допълнително стационарно подгряване на купето с дистанционно управление" - код 536 на цена от 2 939 лв. с ДДС.
Дори при F10/11 за нашия пазар със сигурност не е стандартно, защото е в списъка с допълнително оборудване и е на цена от 3.057 лв.
Регистриран на: 4.09.2009
Местоположение: Kurvenland
Кара: баничарка с компресор
Мнение от da6ip » 09 Окт 2011, 18:02
някъде бях чел че при Е39 се топли и двигателя с циркулиращата охлаждаща течност, но не и при Е60.
при Е60 течността циркулира само през климатика и топли купето, но не и двигателя.
разбира се, след като се запали двигателя той може би се затопля по-бързо ако е загрята една част от охлаждащата течност.
Мнение от da6ip » 09 Окт 2011, 18:05
Emooo написа:Сега намерих в нета от къде си взел този текст. Първо запитването е за е39 и предполагам отговоря е за някоя от страните на север, където е логично да има печка като стандартно обурудване.
+1
в текста се цитира "БМВ ГБ" = БМВ Грейт Британ. Т.е. английския пазар.
Мнение от da6ip » 09 Окт 2011, 18:10
bvv1 написа:
според мен тая тема вече е едно голямо объркване.
объркването идва оттам, че има 2 подгряваши устройства, които хората погрешно наричат "печки".
1. Едното е електрически нагревател вграден в охлаждащата система, който в студени дни след палене нагрява антифриза за да се затопли купето по-бързо. това е серийно на всички 5-ци, но не е "печка".
2. Истинската "печка" е екстра (освен някъде в Слкандинавието или Канада), струва около 1000 Евро, работи с гориво и си има и дистанционно за отделно включване.
Регистриран на: 10.09.2008
Местоположение: Смолян
Кара: E39 530D
Мнение от Ivo_Borisov » 09 Окт 2011, 18:32
При Е39 нафтови печки се вгражда серийно в моделите 520D, 525D, 530D. Действат и като доотоплители и като подгряващи мотора и купето при командване с таймер или дистанционно.
Регистриран на: 28.06.2007
Местоположение: София (големото село)
Кара: е70 sd
Мнение от asasin18 » 10 Окт 2011, 14:01
някой знае ли какво значат тия миганията на дистанционното. броя им се различава но не знам какво точно значи т.е. кога е хванало и кога не :conf:
Регистриран на: 15.02.2011
Кара: F11 530xd / Ex. e61 535d
Мнение от _Maranello_ » 10 Окт 2011, 21:02
da6ip написа:
bvv1 написа:
Благодаря за полезното уточнение ! :clap:
Здраве, безаварийно и безпроблемно!
Регистриран на: 12.11.2007
Кара: X7
Мнение от dpetrov » 10 Окт 2011, 21:04
Аз пак да си попитам - някой има ли наблюдение върху влиянието, което тази благинка оказва върху акумулатора?
F07 535d
F07 530d
E60 530d
Регистриран на: 8.01.2009
Местоположение: Габрово
Кара: F10 530 XD 2011г.
Мнение от Salmi » 11 Окт 2011, 12:39
Здравейте колеги :) Аз да попитам нещо извън темата :oops: Страничните огледала на Е60 2008г. автоматично ли се подгряват или има някакво копче, което не откривам :oops:
Кара: ги да викат
Мнение от bvv1 » 11 Окт 2011, 15:57
da6ip написа:
bvv1 написа:
Не знам дали има такива нагреватели(възможно е),но съм сигурен че БМВ което има печка без значение дали е 1ва 3та 5та или Нта модификация, то тя се включва задължително при ниски температури за спомагане на по-бързо затопляне на купето!
Кара: '16 550d
Мнение от Emooo » 11 Окт 2011, 15:58
Споко, глобалното затопляне обезмисля печките :mhihi:
Кара: е70 sd
Мнение от asasin18 » 11 Окт 2011, 17:17
аз вече почнах да си нося дистанционното па не знам :mhihi:
Назад към Е60/Е61
