2014 M3 F80
- steeN
- Регистриран на: 7.04.2004
- Местоположение: CA
- Кара: конете да бягат
Re: 2014 M3 F80
BMWPOWERRR_ACM написа:…
тези, които са решили за нова кола и тази не ги устройва могат и предпочетат нещо от конкуренцията... не е като да нямат избор точно в момента.
Sent using Tapatalk 2
- BMW_RIDER
- Регистриран на: 30.03.2009
- Местоположение: U gorata
- Кара: prascho, nervaka i redneckmobil
- Мечтае да кара: "samodelna" kola
Re: 2014 M3 F80
DrivinGGoD написа:8)BIMMERPOST написа:http://www.f30post.com/forums/showthread.php?t=753936
We spoke very recently at length to a trusty source within BMW who is familiar with the development of the upcoming F80 M3 sedan / F82 M4 coupe and we were able to confirm the following bits of news:
HORSEPOWER / TORQUE
Regarding power output, the previously estimated 450HP figure is an overestimate. Instead, expect the horsepower output to be in ballpark of the current E90/E92 M3.
What will be increased greatly however, is the torque figure. The F80/F82's multi turbo inline 6 cylinder engine [recently exposed] will add approximately 100 lb-ft more torque over the current M3 (which outputs 295 lb-ft torque). This would put the new M3/M4 in the range of 395 lb-ft torque. There's nothing like forced induction for thrust!
WEIGHT
We were also glad to learn that all this extra torque will not go to waste. We've been reporting that the F80 M3 / F82 M4 will be lighter than the current M3, but how much lighter is what we all want to know. The great news is that the M engineers have targeted the E46 M3 weight in developing the F80/F82.
The E46 M3's curb weight is 3,415 lb, while the current E90 M3 and E92 M3 weigh 3,726 and 3,704 pounds, respectively. This would represent an approximate 300 pound weight reduction; great news for BMW enthusiasts who bemoan the increasing weight of cars in general. The caveat to keep in mind however, is that curb weight is calculated based on the total weight of a vehicle with standard equipment, and with the ever growing list of standard equipment and technology in late model cars, don't be surprised or disappointed if you don't see exactly 300 pounds shaved. What's important is that the E46 M3 weight is being used as a target, which in any scenario, should result in significant weight reduction for the new M3 and M4.
MORE RADICAL M3
This should come as no surprise for those who have been following our F80 M3 spy photos/videos. The F80 M3 sedan will feature a more drastic and aggressive look and styling from the F30 3 Series than the current E90 M3 does from the E90 3 Series. Our source said to think about how the 1M coupe looks compared to the 1 Series, and we believe it. The spy photos already show huge flared fenders, very aggressive front bumper styling, and a raised hood 'bump.' Check out how it may look in some of our preview renders.
TIMING
As for the market release timing - our source again reconfirmed the same schedule we have been reporting. The F80 M3 sedan will be introduced first and will not hit the market until early 2014. Expect the F82 M4 coupe in late 2014 - early 2015. We (just our own guess) think that it may receive a global launch just like the F30 3 Series, where the M3 will hit all markets worldwide simultaneously.
SUMMARY
To recap, here is an updated list of what we know about the F80/F82 so far:
Lighter than current M3
targeting E46 M3 weight
More powerful than current M3
approximately same HP, but around 100 lb-ft more torque (in range of 395 lb-ft)
Faster than current M3
More efficient than current M3
Powered by an inline 6 cylinder multi turbo engine (source, source)
Offered with optional or standard manual transmission
Electric Power Steering (completely reworked for precision for M3/M4)
Tires (from prototype) - Michelin Pilot Super Sport: 255/35/19 (front), 275/35/19 (rear)
Front styling to feature elements from the M6 and 1M coupe, with Air Curtain technology (our render)
Hood to feature power/vent bump
M3 Introduced late 2013 - early 2014 (concept debuts earlier)
M4 Introduced no earlier than late 2014
Stay tuned for more information on the F80 M3 sedan and keep track of our ongoing coverage: http://www.bimmerpost.com/m3/f30m3/
Звучи добре - 500 нм тяга с кривата на турбо мотор и 100 и нещо кила по малко. Мисля ,че на доускорение и в реалния свят дето не си на 8к оборота постоянно, ще се усеща доста по бърза от сегашната мка.
Дам 6.2 атмосферен с брутален звук ми идва на ум...
When I'm on that bike, it's just me and God...And He better be holding on
Re: 2014 M3 F80
немо написа:Jordana написа:Тука чардж кулера е с доста по малък размер от нормалния въздух/въздух тъй като се охлажда с вода .По тоя начин се спестяват много тръби по турбопътищата и са по къси самите турбопътища.Лага е минимален и отпред има място за други агрегати освен това охлаждането е гарантирано а не като при въздушния да зависи от външната температура.Това е по добрия вариант за кулер.
Кое не е ясно ? При конвенционален кулер въздух/въздух имаме пасивно отвеждане на топлината от кулера .Докато при тоя с водата е активно както предполагам има и вентилатор на другия топлообменик освен циркулационната помпа .Освен всичко друго има и положителна инертност заради обема вода в системата.Разбира се че се охлажда с въздух но имаме междинен топлоносител - вода и влизащия в двигателя въздух не зависи пряко от външната темперятура.
Шестака е брутален с това битурбо.Не виждам даже защо се сравнява стария М атмосферен мотор с този като предимствата са му очевадни.
- Bavarcho
- Пантерчо
- Регистриран на: 16.03.2008
- Кара: WBS нов внос
Re: 2014 M3 F80
DrivinGGoD написа:
БМВ правеха красиви двигатели... това ако го нямаше надписа, че е от "бимерпост" щях да помисля, че е мицубиши или тойота
- DrivinGGoD
The Ultimate Driver
- Регистриран на: 23.04.2002
- Местоположение: в света на motorsport-a
- Кара: хората да се учат с ProDrive.bg
- Мечтае да кара: BMW ///M, Ferrari, Porsche, Land Rover
- Детайли за колата: 2003-2005 - '90 BMW E30 318is
2005-2006 - '97 Audi A4 2,6 Avant
2006-2008 - '90 BMW E30 325i Cabrio
2008-2009 - '98 BMW Z3 Roadster
2009-2009 - '96 BMW E34 525tds Touring
2009-2011 - '96 BMW M3 Evo Race Car
2009- - '92 BMW E36 320i
2011- - '98 BMW E36 323Ci
Re: 2014 M3 F80
BMW много отдавна не правят красиви двигатели, а красиви капаци
Просто тук мотора е без него
Are you ///M enough?... - DrivinGGoD's Blog
There's one thing you won't like about your BMW and that's that at some point you'll have to get out!
"Автомобилът ти е истински бърз едва тогава, когато сутрин застанеш пред него и се боиш да го отключиш."-Walter Röhrl
Happiness is not around the corner. Happiness is the corner.
- Bavarcho
- Пантерчо
Re: 2014 M3 F80
DrivinGGoD написа:BMW много отдавна не правят красиви двигатели, а красиви капациПросто тук мотора е без него
За последните мотори съм сългасен, но чак одавна
- DrivinGGoD
The Ultimate Driver
Re: 2014 M3 F80
Ами 10тина години си е отдавна
- немо
- Регистриран на: 25.06.2011
- Местоположение: rustland
- Детайли за колата: Focus,Opel Monza/Senator,MX5 nb
Re: 2014 M3 F80
Jordaná написа:....
Охлаждането(независимо по какъв начин го реализираш) ВИНАГИ зависи от външната температура,щото простата физика е категорична,че не можеш да охладиш нещо на температура по-ниска от охлаждащата среда,в случая температурата на околния въздух
- BMWMHartge
- Регистриран на: 12.09.2003
- Местоположение: с.Градина/гр.Първомай
- Кара: 98' e36 318i
- Мечтае да кара: e36 ///M3
- Детайли за колата: M43B18
- K_Ilkov
- старши СПАМ ентусиаст
- Регистриран на: 8.02.2008
- Кара: е30 чат-пат
- Мечтае да кара: варел
- Детайли за колата: ...
е46 m52b20
е46 m54b30
е83 m54b30
e30 m20b25
е30 m10b18
е46 m54b25
e92 s65b40
Re: 2014 M3 F80
Turturelo написа:колко пъти месечно си дърпате столче да седите и вечеряте на вдигнат капак?
то угодия няма
хем да е леко хем да е по-мощно ... ако може и атмосферно
и естетически издържано под капака ...
пък мен най-много ме дразнят цените, на които ще се продава
Re: 2014 M3 F80
... хем ако излющиш някой пешеходец да не го претрепеш или ако вземеш дърво да не си тотална щета ..
@BMWMHartge - помисли де ..
Re: 2014 M3 F80
немо написа:Jordaná написа:....
Охлаждането(независимо по какъв начин го реализираш) ВИНАГИ зависи от външната температура,щото простата физика е категорична,че не можеш да охладиш нещо на температура по-ниска от охлаждащата среда,в случая температурата на околния въздух![]()
Ами не е съвсем категорична физиката понеже при изпарението си течностите поглъщат топлина и може да се свали температурата под околната.Нарича се фазово превръщане случая не е такъв но по принцип става.Сега замисли се как работи охладителната система на мотора и ще разбереш че това е същия случай.И най доброто въздушно охлаждане работи в пъти по зле от най калпавото водно
- Runnaway
Е46нтусиаст
- Регистриран на: 2.10.2008
- Кара: M3 E46
- Мечтае да кара: M3 E46
- Детайли за колата: BMW E46 M3 '03 - Carbon Black & Manual Gearbox
Re: 2014 M3 F80
BMWMHartge написа:Защо се води Ф80, като седана е Ф30?
Предполагам, че си забелязал тенденцията новите шасита да са с различни entwicklung nummer-чета. И това е от Е60/90 насам.
2008 - 2015 F01 BMW 7er Limousine Serie
2008 - 2015 F02 BMW 7er Limousine - Langversion Serie
2009 - 2015 F03 BMW 7er Limousine - Protection Serie
2010 - 2015 F04 BMW 7er Limousine - ActiveHybrid Serie
2011 - 2018 F06 BMW 6er Gran Coupé Serie
2009 - 2016 F07 BMW 5er Gran Turismo (ehemals RFK - Raumfunktionales Konzept / PAS) Serie
2010 - 2017 F10 BMW 5er Limousine Serie
2011 - 2018 F11 BMW 5er Touring Serie
2012 - 2019 F12 BMW 6er Cabrio Serie
2011 - 2018 F13 BMW 6er Coupé Serie
2012 - 2019 F14 BMW 6er Gran Coupé (ehemals BMW Concept CS) Serie
2013 - 2020 F15 BMW X5 - Sports Activity Vehicle Serie
2010 - 2016 F18 BMW 5er Limousine - Langversion für China Serie
2011 - 2018 F20 BMW 1er 5-Türer Serie
2012 - 2019 F21 BMW 1er 3-Türer Serie
2014 - 2021 F22 BMW 2er Coupé Serie
2014 - 2021 F23 BMW 2er Cabriolet Serie
2011 - 2018 F25 BMW X3 - Sports Activity Vehicle Serie
2012 - 2019 F30 BMW 3er Limousine Serie
2012 - 2019 F31 BMW 3er Touring Serie
2012 - 2019 F32 BMW 3er Coupé (4er-Reihe) Serie
2012 - 2019 F33 BMW 3er Cabrio (4er-Reihe) Serie
2013 - 2020 F34 BMW 3er Gran Turismo Serie
2015 - 2022 F35 BMW 3er Limousine (Langversion China) Serie
2013 - 2020 F44 BMW 1er GT (Frontantrieb) Serie
2014 - 2021 F45 BMW 1er touring (Frontantrieb) Serie
2014 - 2021 F46 BMW 1er City (Frontantrieb) Serie
2013 - 2020 i3 BMW i3 (Megacity Vehicle - Project i) Serie
2014 - 2016 i8 BMW i8 (BMW Vision EfficientDynamics) serie
2014 - 2022 FAST Family Activity Sports Tourer Serie
Из http://www.bmwarchiv.de/e-code/
- djkita
- Регистриран на: 27.05.2008
- Местоположение: Пазарджик/Пловдив
- Кара: E36 Coupe & E46 Coupe
Re: 2014 M3 F80
Да де то това е ясно, ама М6 Купе си е пак Ф13, М6 кабриолет отново Ф12, М5 също си е Ф10 както 'обикновената'' 5ца. Въпроса е защо М-версията на Ф30 ще се казва Ф80..... това нещо не го разбираме!
