WTCC 320i , 320si
Регистриран на: 5.04.2005
WTCC 320i , 320si
Мнение от MaXimal » 12 Ное 2006, 18:43
BMW 320si
Engine
4-cylinder in line, longitudinally installed; distribution: two overhead camshafts, 16 valves; displacement: 1999 cc; bore x stroke: 86 x 86 mm; compression ratio: 11:1; maximum output: 275 bhp @ 8300 rpm; maximum torque: 242 nm @ 7250 rpm; engine management: BMW Motorsport ECU 404; lubrication: wet sump.
Transmission
Rear-wheel-drive; gearbox: BMW Hpattern 5-speed, with straight cut gears and dog engagement; clutch: carbon-fibre single-plate; differential: mechanical limited slip differential.
Dimensions
Length: 4535 mm; width: 1845 mm; wheelbase 2763 mm; minimum weight: 1140 kg including the driver.
Chassis/suspension/tyres/wheels
Front suspension: double-joint strut, coil springs, gas-filled dampers, anti-roll bar; rear suspension: five-arm multi link axle, coil springs, gas-filled dampers, anti-roll bar; steering: power assisted rack and pinion.
Brakes & Wheels
Power assisted dual circuit system; front brakes: 4-piston calipers, 332 mm steel ventilated discs; rear brakes: 2-piston calipers, 291 mm steel discs.
BMW 320i
Engine
6-cylinder in line, longitudinally installed; distribution: two overhead camshafts, 24 valves; displacement: 1993 cc; bore x stroke: 80 x 66 mm; compression ratio: 11:1; maximum output: 275 bhp @ 8800 rpm; maximum torque: 230 nm @ 7000 rpm; engine management: BMW Motorsport ECU 12A; lubrication: wet sump.
Transmission
rear-wheel-drive; gearbox: BMW Hpattern 5-speed, with straight cut gears and dog engagement; clutch: carbon-fibre single-plate; differential: mechanical limited slip differential.
Dimensions
length: 4490 mm; width: 1809 mm; wheelbase 2742 mm; minimum weight: 1140 kg including the driver.
front suspension: McPherson strut, coil springs, gas-filled dampers, anti-roll bar; rear suspension: central link arm with double wishbone, coil springs, gas-filled dampers, anti-roll bar; steering: power assisted rack and pinion.
Brakes & Wheels
power assisted dual circuit system; front brakes: 4-piston calipers, 332 mm steel ventilated discs; rear brakes: 2-piston calipers, 280 mm steel discs.
Това е от сайта на една игра, дали е вярно ?
...и то хидравличен :)
Регистриран на: 1.12.2003
Кара: джата
Мечтае да кара: на Ринга
Детайли за колата: Двете 2и2ки
Мнение от krika » 12 Ное 2006, 19:36
Ми тва са данните доколкото е позволено да се казват на новата WTCCтка и старата шампионска е46ца с 6цилиндровия матор.Какъв ти е точно въпроса не разбрах :roll:
Мнение от MaXimal » 12 Ное 2006, 20:39
Ами дали тези данни са верни,това ми е въпросът.
Регистриран на: 27.12.2004
Кара: м42б20 турбо
Детайли за колата: hx35/40 twin scroll
Мнение от S-stail » 12 Ное 2006, 21:00
Тия данни съм ги гледал в едно списание,но
нищо не пишеха за Нм.Чудно ми е как 6ка прави
по малко въртящ момент?
Uploaded with ImageShack.us
Loosing Traction is part of the fun!!
Мнение от MaXimal » 12 Ное 2006, 21:05
Интересно клипче http://www.e90post.com/forums/showthread.php?t=33946
Разработването на 320Si
Регистриран на: 7.04.2004
Местоположение: CA
Кара: конете да бягат
Мнение от steeN » 12 Ное 2006, 22:07
мда вярни са... всички коли във WTCC в момента са по ~270 коня два литра ;) може да провериш на официалния сайт на шампионата...
Кара: джата
Мнение от krika » 12 Ное 2006, 23:27
[steeN] написа:мда вярни са... всички коли във WTCC в момента са по ~270 коня два литра ;) може да провериш на официалния сайт на шампионата...
бе той никой не си казва точните коне ма няа как да излъжат за по-малко от 270кс и за тва така ;)
Местоположение: CA
Мнение от steeN » 12 Ное 2006, 23:59
важното е, че бая са ги напънали тия двигатели :)
Кара: джата
Мнение от krika » 13 Ное 2006, 1:59
[steeN] написа:важното е, че бая са ги напънали тия двигатели :)
може и още...гърч на железото трябва :mhihi:
Мнение от MaXimal » 13 Ное 2006, 9:16
То хубаво са ги напънали бая, ама колко време издържа един такъв двигател :confused:
Регистриран на: 10.08.2005
Кара: F11 535d, E84 2.3d
Мнение от vld » 13 Ное 2006, 11:08
MaXimal написа:То хубаво са ги напънали бая, ама колко време издържа един такъв двигател :confused:
Бате в спорта това не е от значение ;)
Важното е да си пръв :winky:
Регистриран на: 21.11.2003
Кара: си Е65-цата.
Мнение от ///M Power » 13 Ное 2006, 12:18
издържат доста май,ако не бъркам си издържат почти целия сезон(който не е чак толкова много)....гледам ги от 2-3г. и до сега някой да счупи мотор не съм виждал :mhihi:
- Mario Andretti
автомобилен поклонник
Регистриран на: 17.02.2002
Мнение от Turturelo » 13 Ное 2006, 14:27
да .. наливат му бензин и карат цял сезон. Даже като са свободни ходят с тия коли на море .. камби за туршия да купуват .. разсад мъкнат за дворовете да си сядат .. по 400-500 000км. им въртят .. само масло сменят и доливат течност за чистачките! То BMW .. :D
Регистриран на: 16.09.2003
Кара: 328i
Мнение от Leon » 13 Ное 2006, 15:46
При това ги правят с А95 от Шел тия коне :mhihi:
Хора, що се излагате - тия двигатели я изкарат едно състезание, я не... Ако изкарат - след това ги разкостват на съставни части и пълен рециклаж за следващото състезание. Иначе данните са впечатляващи. Владо, няма ли да докарате едно такова за тест на Абажурище? :roll: :winky:
Мнение от MaXimal » 13 Ное 2006, 16:39
Turturelo написа:да .. наливат му бензин и карат цял сезон. Даже като са свободни ходят с тия коли на море .. камби за туршия да купуват .. разсад мъкнат за дворовете да си сядат .. по 400-500 000км. им въртят .. само масло сменят и доливат течност за чистачките! То BMW .. :D
Нали знаеш, че едно БМВ върви повече когато е на много километри :mhihi:
Назад към Основен Форум
